Alphacool Core RX 9070 XT Swift + Quicksilver with Backplate
- Article no.: 14799
- EAN: 4250197147996
- Weight: 1,254 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
The GPU water cooler has been completely overhauled technically. To optimize cooling performance, the distances between the cooler and the components of the PCB were redefined and tested. The water flow was simulated using the most advanced software and verified through practical tests. These extensive tests allowed for improvements to the cooler base and jetplate, ensuring the best possible cooling performance for the new AMD Radeon RX generation.
Important!
For the XFX AMD GPU variants Quicksilver and Swift, multiple PCB versions exist. Our GPU water block is only compatible with version V2.0, older PCB versions (e.g. A.0) are not supported.
- XFX Quicksilver AMD Radeon RX 9070XT Gaming Edition (RX-97TQIC V2.0)
- XFX Quicksilver AMD Radeon RX 9070XT White Gaming Edition (RX-97TQICKW9)
- XFX Swift AMD Radeon RX 9070XT White Triple Fan Gaming Edition (RX-97TSWF3W9 V2.0/V3.0)
| Technical data cooler | |
| Dimensions total (L x W x H) | 195,60 x 127,30 x 33,35mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 10 |
| Color | transparent |
| Dimensions (L x W x H) | 195,60 x 98,80 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
