Alphacool Apex Stealth Metal Power Fan 3000rpm Matt Black (120x120x25mm)
  • 13823
  • 4250197138239
  • 0,2 kg
€21.98 * €29.98 * (26.68% Saved)
RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
€104.98*
LZ Alphacool Core 10x 4-Pin PWM Splitter with SATA power connector
€11.98*
LK Alphacool Y-Splitter 3-Pin to 3x 3-Pin 30cm
€2.98*
L12 Alphacool Apex Stealth Metal Power Fan 3000rpm Matt Black (120x120x25mm) 3x
Instead of €65.94 * (10% saved) Price for all: €59.34 *
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth Power can be controlled between 400 to 3000 rpm via the 4-pin PWM connector. The startup speed is ~500 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Dimensions (L x W x H)120 x 120 x 25,5mm
Material (Frame)Die-cast zinc
Material (Impeller)Plastic
Weight320g
Speed400~3000±10% rpm
BearingHydro Dynamic Bearing
Connection4-Pin PWM
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption6.60 Watt
Rated Current0.50 A (0.55Max)
Air Flow70.98 CFM
Static Air Pressure4,23 mmH2O
Noise Level40.1 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
Colormatte black
Warranty: 5 years
Awards & Videos
Rated speed range: 400 - 3000 U/min
Air conveying area: 100 - 149 m³/h
Air flow rate: 120,595 m³/h
Pressure: 4,23 mm H2O
Color Frame: Black
Rated speed: 3000 U/min
Color Rotor: Black
Nominal voltage: 12V DC
Volume: 40,2 dB(A)
RPM signal transmission: Yes
Volume range: 30 - 49,9 dB(A)
Lebensdauer (bei 25°C): 100.000 h
Power connection: 4Pin
Dimensions: 120 x 120 x 25mm
LED: Unavailable
Power consumption: 6,6W
€21.98 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
€99.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Liefertermin: in 2 - 3 Wochen
€34.98 *
€2.98 *
€65.99 *
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
Content 6 Stück (€2.16 * / 1 Stück)
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
