Alphacool ES 2U Reservoir VPP/D5 with flow/temperature sensor
  • 13741
  • 4250197137416
  • 1,401 kg
€219.98 *
€439.98*
€79.98*
17635 Alphacool ES deionized water (ultrapure water) 5000ml
€69.98*
13738 Alphacool ES 19" Open Frame Serverrack 25U Adjustable Depth
€289.98*
The Alphacool ES 2U Reservoir is a versatile reservoir optimized for use in 2U server cases. The... more
The Alphacool ES 2U Reservoir is a versatile reservoir optimized for use in 2U server cases. The quick-release fasteners on the front ensure quick and easy maintenance. The cooling system can be continuously monitored using the integrated flow and temperature sensors. The illuminated window makes the fill level easy to read at any time.
Optimized for servers
The Alphacool All-in-One reservoir has been specially developed for 2U server cases. The device has a compact design to take up as little space as possible in the server case. Due to the quick-release fasteners on the front, the cooling system can be filled and vented quickly and easily. The illuminated window makes it possible to check the fill level in the system at any time. The Alphacool ES 2U reservoir is compatible with pumps using D5 format such as the Alphacool VPP Apex.
Integrated sensors
The reservoir has a temperature sensor that covers a measuring range of -40 to 125°C and is connected to the mainboard via a 2-pin connector. In addition, a flow sensor, which is connected via a 3-pin connector, enables continuous monitoring of the water flow in the cooling system.
Dimensions (L x W x H) (without pump)99.66 x 146.00 x 83.90mm
MaterialMetal, acetal
Weight1500g
Threads (front side)2x quick-release fastener G1/4”
Threads (rear side)1x G1/4" In | 1x G1/4" Out
Connection flow sensor3Pin
Connection temperature sensor2Pin
Connection aRGB3-Pin 5V
Pump compatibilityD5/VPP
Max working temperature60 °C
Pressure tested0.8 bar
WAC Alphacool ES Stream LGA 4677 / SP5 LGA 6096 1U
€132.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
