Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
  • 13523
  • 4250197135238
  • 0,02 kg
€6.99 *
Content: 100 cm² (€0.07 * / 1 cm²)
13036 Alphacool Apex 17W/mK Thermal grease 4g
€15.98*
13097 Alphacool Apex 17W/mK Thermal grease 50g
€129.98*
13415 Alphacool Core Thermal Pad Soft 9W/mk 100x100x0,5mm
€23.98*
13491 Alphacool Apex Thermal Pad Soft 16W/mk 100x100x0,5mm
€49.98*
Alphacool's double-sided adhesive Core thermal pad can be used to cool electronic components of... more
Alphacool's double-sided adhesive Core thermal pad can be used to cool electronic components of all kinds where it is important to effectively dissipate waste heat. This significantly improves the performance and durability of the components. The assembly is significantly simplified by the material-related tackiness.
Flexible and Powerful.
Due to its material composition, the thermal conductive pad is reliable and powerful. With its low thickness, it offers a wide range of application possibilities. It can be flexibly cut to size for individual needs. The adhesive nature allows effortless mounting of electrical components such as DDR modules, motherboard components or power supplies.
Dimensions (L x W x H)100x100x0.25mm
Thermal Conductivity (ASTM D5470)1 W/mK ±10%
Thickness (ASTM D374)0.25 mm
Reinforcement CarrierFiberglass mesh
Continuous Working Temperature-30~+120 °C
Short time use temperature (30sec)180 °C
Density (ASTM D792)1.2 g/cm³
Holding Power 1000g@25° Cusing 1 in² (PSTC-7)>3000 min
180° Peeling Strength (aluminum) (PSTC-101)>16 N / 25mm
Dielectric Breakdown Voltage (AC) (ASTM D149)3 KV ±10%
Thermal Impedance @10psi (ASTM D5470)1.26 C-in² / W
Thermal Impedance @30psi (ASTM D5470)1.06 C-in² / W
Thermal Impedance @50psi (ASTM D5470)1.05 C-in² / W
Colorwhite
Flächenmaße: 100 x 100mm
Dicke: 0,25mm
Befestigung: stark klebend
Alphacool double-sided adhesive pad 15x15x0,5mm
Content 2.25 cm² (€0.66 * / 1 cm²)
€1.48 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x2mm orange marked PE Bag (24 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x2mm red marked PE Bag (24 pcs)
Content 54 cm² (€0.07 * / 1 cm²)
€3.78 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm
Alphacool Eisschicht thermal pad - 11W/mK 100x100x1,5mm
Content 100 cm² (€0.60 * / 1 cm²)
€59.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück
Alphacool Eisschicht thermal pad - 11W/mK 120x20x0,5mm - 2 Stück
Content 48 cm² (€0.52 * / 1 cm²)
€24.98 *
WAR Alphacool GPU RAM Aluminium Heatsinks 7x7mm - black 10 Stk.
Alphacool GPU Heatsinks RAM Alu 7x7mm - black 10 Stk.
€4.98 *
WAK Alphacool ES RTX A4000 mit Backplate
Alphacool ES RTX A4000 with Backplate
€159.98 *
Alphacool Core 1 Aurora Black
€119.98 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.50 * / 1 cm²)
€4.48 *
Alphacool y-splitter aRGB 3-pin to 2x 3-pin 60cm
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
€4.48 *
WAR Alphacool ES Passive Aluminium Cooler 100x120x22mm
€25.98 *
KOI Alphacool Core Ocean T38 AIO 360mm
€85.98 *
KOI Alphacool Core Ocean T38 AIO 120mm
€62.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
L12 Alphacool Core 120mm Lüfter PWM 4000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 4000rpm (120x120x25mm)
€10.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3090 Founders Edition mit Backplate
Alphacool Eiswolf 2 AIO - 360mm RTX 3090 Founders Edition with Backplate
€219.98 * €269.98 *
KOI Alphacool Core Hurrican 360mm XT45 HardTube Wasserkühlungs Set
Alphacool Core Hurrican 360mm XT45 HardTube water cooling Set
€429.98 * €449.97 *
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
Alphacool Rise Thermal grease 6W/mK 4g
€5.99 * €8.98 *
RAD Alphacool ES Aluminium 360 mm T38  - (For Industry only)
€36.98 *
€44.98 *
Alphacool tubing AlphaTube HF 10/8 (5/16"ID) - Ultra Clear 3m (9,8ft) Retailbox
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
RAD Alphacool NexXxoS ST25 Full Copper 360mm Radiator
Alphacool NexXxoS ST25 Full Copper 360mm radiator
€64.99 * €77.98 *
WAC Alphacool Eisblock XPX Aurora - Acryl Black Digital RGB
€54.98 * €65.99 *
€23.28 *
RAD Alphacool NexXxoS XT45 Full Copper 480mm Radiator V.2 PHT EOL
Alphacool NexXxoS XT45 Full Copper 480mm radiator V.2
€109.98 * €136.98 *
RAD Alphacool NexXxoS XT45 Full Copper 240mm Radiator V.2
Alphacool NexXxoS XT45 Full Copper 240mm radiator V.2
€79.98 * €89.98 *
ANK Alphacool HF Schnellverschlusskupplungsset G1/4 - Black
Alphacool HF quick release connector kit G1/4 - black
AGZ Alphacool Aurora LED Ring 60mm - RGB
€11.98 * €14.98 *
WACZ Alphacool NexXxoS XP³ Halterung für Radeon Ryzen S. AM4
Alphacool NexXxoS XP³ bracket for Radeon Ryzen S. AM4
ANS Alphacool Eiszapfen 12mm HardTube Anschraubtülle G1/4 - Chrome Sixpack
Alphacool Eiszapfen 12mm HardTube compression fitting G1/4 - knurled - chrome sixpack
Content 6 Stück (€4.16 * / 1 Stück)
€24.98 * €29.89 *
