Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x0,5mm
  • 12975
  • 4250197129756
  • 0,01 kg
Content: 100 cm² (€0.10 * / 1 cm²)
12879 Alphacool Eisfrost Xtreme liquid metall paste 1g
€6.99*
12976 Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1mm
€19.98*
The Eisschicht from Alphacool can, like other thermal pads, compensate for the irregularities of... more
The Eisschicht from Alphacool can, like other thermal pads, compensate for the irregularities of heat sinks and the elements to be cooled. But it has a great feature: The Eisschicht consists of thermal paste with an embedded mesh! This ensures that the performance of these pads is much more efficient than normal thermal pads, regardless of the low W/mK value. In addition, a better distribution and filling between the surfaces is achieved. This also results in better air displacement. Due to their soft consistency, there is also no pressure on components or solder joints. Nvidia also uses this kind of pads for the Founders Edition. The Eisschicht can be easily cut to the desired size and attached to heat sinks without slipping.
As a basic component or spare part, thermal pads belong in every well-organized computer tinkering corner!
Dimensions (L x W x H)100 x 100 x 0,5mm
Thermal conductivity3 W/mK
Electrical ConductiveNo
Colorwhite
€0.98 *
€1.19 *
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€24.98 *
WAGZ Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 100x100x1mm
Content 100 cm² (€0.20 * / 1 cm²)
WAGZ Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 50x50x3mm
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 50x50x3mm
Content 25 cm² (€0.40 * / 1 cm²)
€1.89 *
€29.98 *
Delivery date: in 5 - 6 days
Alphacool ES Orbiter 360 TS
€549.98 *
€25.98 *
Alphacool Eiszapfen 14mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€34.98 *
Delivery date: in 6 - 7 weeks
17%
€38.98 *
Phobya VGA Power Connector 6+2Pin plug incl. 8 pins - 2 pieces Black
Content 2 Stück (€1.44 * / 1 Stück)
€2.87 *
