Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1mm - 2 pieces
- Article no.: 12469
- EAN: 4250197124690
- Weight: 0,05 kg
| Hersteller: | Alphacool |
| Fastening: | Slightly adhesive |
| Thickness: | 1,0mm |
| Surface dimensions: | 120 x 20mm |
| Thermal conductivity: | 17W/mk |
