  • 12457
  • 4250197124577
  • 0,05 kg
€28.98 *
Content: 48 cm² (€0.60 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 120 x 20mm
Thermal conductivity: 11W/mk
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.31 * / 1 cm²)
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück
€21.98 *
€29.98 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.40 * / 1 cm²)
Content 6 Stück (€2.66 * / 1 Stück)
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm
Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
Alphacool Core thermal pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core thermal pad Soft 6.2W/mk 100x100x2mm
€24.98 *
€1.89 *
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€30.00 *
33%
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
€5.99 * €8.98 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
€6.99 *
WAGZ Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x1,5mm
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1,5mm
Content 10 Stück (€1.30 * / 1 Stück)
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.28 * / 1 Stück)
€4.98 *
WACZ Alphacool Eisbaer Federn und Muttern
Alphacool Eisbaer springs and nuts
€4.48 *
€23.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.46 * / 1 cm²)
€69.98 *
Alphacool NexXxoS GPX accessory pack 3W/mk
Content 108 cm² (€0.04 * / 1 cm²)
€3.97 *
