Thermal pads
Top seller
WAGZ Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x1,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1,5mm
€1.19 *
€0.98 *
Close filters
from to
1 From 5
WÄM Alphacool Wärmeleitklebepad doppelseitig 15x15x0,5mm Alphacool thermal adhesive pad double-sided 15x15x0.5mm
Alphacool's answer to the often unsolvable problem: "The cooler cannot be screwed on!" With the double-sided thermal adhesive pad from Alphacool, you can mount your cooler in the desired location regardless of hole spacing,...
€0.98 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 30x30x0,5mm Alphacool thermal adhesive pad double-sided 30x30x0.5mm
€1.19 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x1,5mm red marked PE Bag (24 Stück) Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x1.5mm red marked PE Bag (24 pieces)
Alphacool's new thermal pads with 3W/mk The inevitable differences in height and unevenness on the heat sinks and the elements to be cooled as well as the smallest grooves can be compensated thanks to the very elastic contact...
Content 54 cm² (€0.06 * / 1 cm²)
€3.18 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x3mm yellow marked PE Bag (24 Stück) Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x3mm yellow marked PE Bag (24 pieces)
Content 54 cm² (€0.12 * / 1 cm²)
€6.29 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück) Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x2mm orange marked PE Bag (2 Stück) Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x2mm orange marked PE Bag (2 pieces)
Content 18 cm² (€0.12 * / 1 cm²)
€2.19 *
WAGZ Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 15x15x2mm orange marked PE Bag (24 Stück) Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x2mm orange marked PE Bag (24 pieces)
Content 54 cm² (€0.07 * / 1 cm²)
€3.78 *
Delivery date: in 9 - 10 days
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm EOL Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1mm
Alphacool's ultimate solution for cooling your computer with a layer of ice. Not a layer of ice in the traditional sense made of frozen water, but a layer that will freeze any chip. The properties of the new thermal pads speak for...
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm PHT EOL Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.31 * / 1 cm²)
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x1mm - 2 pieces
€21.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€0.60 * / 1 cm²)
€28.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x0,5mm PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
Content 100 cm² (€0.47 * / 1 cm²)
€46.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.80 * / 1 cm²)
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1,5mm PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1.5mm
Content 100 cm² (€1.20 * / 1 cm²)
€119.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.62 * / 1 cm²)
€29.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1mm - 2 pieces
Content 48 cm² (€1.04 * / 1 cm²)
€49.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.46 * / 1 cm²)
€69.98 *
1 From 5
