Alphacool Eisbecher Helix 250mm reservoir - red
  • 15300
  • 4250197153003
  • 1,081 kg
€49.99 * €89.98 * (44.44% Saved)
The Alphacool Helix Eisbecher captivates with its unique Helix Optic, including elegant... more
The Alphacool Helix Eisbecher captivates with its unique Helix Optic, including elegant aluminium caps for its upper and bottom sides. The 60mm diameter version also offers a UV cathode tube to illuminate UV-reactive water from within.
Highlights
  • Helix Optic
  • Four colour combinations
  • Two diameter sizes - 50mm and 60mm
  • 60mm version comes with UV cathode tube
The Alphacool Eisbecher Helix 250 is the optical highlight of the Eisbecher family. The helix inside the reservoir gives off a unique effect reminiscent of a strand of DNA, making it a real eye-catcher. In the middle of the reservoir is a UV cathode tube powered over a 4-pin plug. If UV-reactive water is used, the cathode tube will create a strong glow from the inside of the reservoir, making for a unique effect that really impresses.
The base and top are made entirely of acetal, but are covered with aluminium caps for an elegant look. The aluminium caps do not come in contact with the water, of course. The installation options are considerable, with three G1/4 threads in both the bottom and top. The bottom also has two extra G1/4 connection points. This gives you lots of options for positioning your reservoir.
You'll also receive two different installation sets. One of them is well-known from the Eisbecher series - the aluminium brackets that lock flush with the top and bottom of the Eisbecher and provide the option of mounting on a radiator. This requires a 240 or 280mm radiator or a larger equivalent, such as a 360 or 420mm. The alternative installation set is a clip bracket, made up of two clips which are fastened to the case with one screw each. The Eisbecher Helix just needs to be clipped on, giving you lots of flexibility in how you mount it.
The Eisbecher Helix is available in multiple colour combinations. The cap, bottom, and the helix itself can all be different colours.
Technical Specifications
  • Dimensions (HxD): 250 x 65mm
  • Connection threads: 8x G1/4"
  • Helix colour / aluminium caps: red / red
  • UV cathode colour: UV
  • Cable length: ca. 27cm
  • Capacity: 340ml
Scope of Delivery
  • 1x Alphacool Eisbecher Helix 250mm Reservoir - red
  • 1x UV cathode
  • 1x Adapter
  • 2x Aluminium brackets - Eisbecher series
  • 2x Bracket clips - black
  • Assembly materials
  • 6x Locking screws
Datasheet
Installation Manual
Download 3D-file (.stp)
Behältertyp: Röhrenbehälter 60mm
Pumpenkompatibilität: für Durchflusspumpen
Pumpe vorinstalliert: Nein
Farbe: transparent;
Anschluss: G1/4" Innengewinde
Anzahl Anschlüsse: 6
Fillport: G1/4" Innengewinde
Abmessungen: 60 x 60 x 250mm
LED Bohrungen: nicht vorhanden
Material: Acryl;Aluminium;
Volumen: 340ml
NEW
AGB Alphacool Core Flat Reservoir 240 Right D5/VPP
€149.98 *
NEW
AGB Alphacool Core Flat Reservoir 360 Right D5/VPP
€189.98 *
AGB Alphacool Repack Single Bayres 5,25" - Rev.2
€27.98 * €40.00 *
AGB Alphacool Eisbecher 250mm Acetal Ausgleichsbehälter EOL
Alphacool Eisbecher 250mm Acetal reservoir
€37.98 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
€2.98 *
Alphacool Digital RGB LED y-cable 3-times with JST male connector 30cm - black
AGB Alphacool Eisbecher Helix 250mm Ausgleichsbehälter - blau EOL
Alphacool Eisbecher Helix 250mm reservoir - blue
€49.99 * €80.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
€3.98 *
€99.98 *
Liefertermin: in 2 - 3 Tagen
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Alphacool Eiszapfen 16/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
Content 4 Stück (€10.50 * / 1 Stück)
€41.98 *
Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Chrome
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Chrome
Content 4 Stück (€12.50 * / 1 Stück)
€49.98 *
L14 Alphacool Rise Aurora 140mm Lüfter Weiß (140x140x25mm)
€18.98 * €24.98 *
L12 Alphacool Rise Aurora 120mm Lüfter Weiß (120x120x25mm)
€15.98 * €21.98 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference EOL
€49.98 * €86.98 *
KOI Alphacool Core Wind 240mm ST30 Wasserkühlungs Set
Alphacool Core Wind 240mm ST30 water cooling Set
€219.98 * €229.98 *
€65.99 * €89.23 *
Liefertermin: in 2 - 3 Wochen
WAH Alphacool HDX Apex Acryl aRGB M.2 2280 SSD Kühler
Alphacool HDX Apex Acrylic aRGB M.2 2280 SSD Cooler
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€30.00 *
€44.98 *
Leak Testing Tool incl. Pump
€34.98 *
