Alphacool Lighting LED Logo - Blue (white led)
- Article no.: AGZ
- EAN: 4250197152563
- Weight: 0,005 kg
- Available:
Alphacool Lightning LED Logo - Blue - Spare part for the Alphacool ice compartments.
The logo can also be used with little effort to jazz up your computer with LED technology. Either directly on the front of the case or inside the case. This Alphacool Lightning LED logo gives the modding the finishing touch.
Technical data:
- Dimensions (LxWxH): 53 x 13.5 x 4mm
- Material: Plastic
- 2x white LEDs
- Connector: 3Pin
- Cable: 30cm sleeved
- 1x Alphacool Lightning LED Logo - Blue (white led)
![S16 Alphacool Eisrohr 16/13mm PETG HardTube 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/26/ea/e2/1012520_1_200x200..jpg)
![S16 Alphacool HardTube 16/13mm Acryl (PMMA) Klar 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/16/b3/c1/1011144_1vdsrONvgzSy7v_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 60cm weiß](https://aquatuning.shop-cdn.com/media/image/0a/1e/67/1023496_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 30cm weiß](https://aquatuning.shop-cdn.com/media/image/71/17/a4/1023495_01_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x0,5mm](https://aquatuning.shop-cdn.com/media/image/56/6d/c5/1023191_1sdW3bvAjFuohw_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x3mm](https://aquatuning.shop-cdn.com/media/image/14/52/ea/1023190_12OTFy5F7BeaIn_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x2mm](https://aquatuning.shop-cdn.com/media/image/4f/b5/6e/1023189_1MezOSnbGtPKp0_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 15cm](https://aquatuning.shop-cdn.com/media/image/9c/4e/8b/1023109_01_200x200..jpg)
![WAZ Alphacool ES VE-Wasser (Reinstwasser) 5000ml](https://aquatuning.shop-cdn.com/media/image/13/3c/b7/1023014_1tMAG4GtpGURJq_200x200..jpg)
![WAGZ Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 100x100x1,5mm](https://aquatuning.shop-cdn.com/media/image/80/b9/b7/1023008_15V7tjSuKcBB2v_200x200..jpg)
![WÄM Alphacool Apex 17W/mK Thermal grease 4g](https://aquatuning.shop-cdn.com/media/image/2b/b5/16/1022240_1gxSgfGrdtkDJV_200x200..jpg)
![S16 Alphacool Carbon HardTube 16mm 4x 80cm](https://aquatuning.shop-cdn.com/media/image/a4/da/2b/1021877_10hncUBYRYokb1_200x200..jpg)
![WÄM Alphacool Apex Soft Wärmeleitpad 11W/mk 100x100x1mm](https://aquatuning.shop-cdn.com/media/image/45/0f/73/1021777_1Rl6gTg254lB60_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm](https://aquatuning.shop-cdn.com/media/image/32/00/5e/1021763_1PFyMpyHDB5PBY_200x200..jpg)
![S11 Alphacool EPDM Tube 11/8 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/c8/7c/fc/1021506_01_200x200..jpg)
![PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe](https://aquatuning.shop-cdn.com/media/image/84/84/25/1019164_1VI1uAaOVHpQG4_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
