Alphacool Eisfach - Single Laing D5 with VPP Apex PWM pump
- Article no.: 13304
- EAN: 4250197133043
- Weight: 1,214 kg
- Available: Currently there are 2 available - More is on the way
| Technical data Eisfach | |
| Material | plastic, metal |
| Color | Black |
| Dimensions (L x W x H) | 148 x 132 x 84,5mm |
| Connection thread | 10x 1/4" |
| Lighting | 2x 5mm LED |
| Technical data VPP Apex | |
| Dimensions (L x W x H) | 65x65x41mm |
| Material pump | synthetic material |
| Material pump cover | aluminium |
| Material axle | ceramics |
| Cable connections | 4-pin PWM | SATA |
| Rotational speed | 2500 - 4500 RPM |
| Cable lengths | 4-Pin PWM - 48cm | SATA - 48cm |
| Operating voltage | 8-13V DC / 14W IP32 |
| Starting voltage | 12V DC |
| Maximum pumping head | 4.25m |
| Maximum flow rate | 340L/h |
| Weight | 276g |
| Color | Black |
