Alphacool NexXxoS HPE-45 Full Copper 80mm Triple Radiator
  • 14438
  • 4250197144384
  • 0,777 kg
  • 10
13295 Alphacool Eisstation D5 reservoir with VPP Apex PWM pump
€83.98*
12961 Alphacool Eisblock XPX 1U - Black Acetal Version
€79.98*
€19.98*
€18.98*
€14.98*
Alphacool is uncompromising in its choice of materials and is the only manufacturer in the world... more
Alphacool is uncompromising in its choice of materials and is the only manufacturer in the world that uses only copper for all water-bearing parts in the radiator. The pre-chambers, cooling fins and cooling channels are made of pure copper. Only the fitting threads (made of brass) and the outer casing of the radiator (made of sheet steel) are made of other materials.
HPE = High Performance
The HPE radiators are based on the NexXxoS series. But what is new? The HPE variant has additional cooling channels and a very high fin density. Due to the technical design, the cooling capacity increases significantly without restricting the water flow within the radiator. If the radiator is equipped with fans on both sides in push/pull operation, it is possible to achieve a significant temperature reduction compared to standard radiators.
Powerful cooling performance
To maximise the performance of the radiator, Alphacool reaches deep into its bag of tricks and uses pure copper for the cooling fins, cooling channels and pre-chambers. Due to the high thermal conductivity of 400 W/mK (in comparison: aluminium 236 W/mK). The high fin density of the radiator with a fin spacing of 16 FPI enables an optimal flow of air. All cooling fins are additionally equipped with small flaps. These are tiny wings that direct the airflow in the desired direction and ensure controlled air turbulence. This increases the cooling capacity and minimises the possible noise created by airflow.
Connection options & mounting
The NexXxoS HPE radiators each have an IN & OUT connection with G1/4" thread. All screws for mounting the fans are included with the radiator. Additional screws are usually not required.
Safety first
Technical data radiator
L x W x H286 x 80 x 42 mm (±3 % tolerance in the range of the prechamber)
Quantity of cooling channels16
Material threadsbrass
Threads2x G 1/4 IN/OUT (max. 5 mm thread length)
Possible fan size80 mm
Possible fan assembly3x one-sided / 6x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density16 FPI
Weight630 g
Warranty: 10 years
€34.98 *
€37.98 *
