Alphacool NexXxoS Monsta 120mm radiator
- Article no.: 14180
- EAN: 4250197141802
- Weight: 1,17 kg
Info about the Monsta radiators:
The Monsta radiators, with a thickness of 80mm, are the first of their size on the market. Hence we were just as keen on finding out how they perform as the independent reviewers!
The tests show that it has significantly increased flow rates than thinner radiators. The cooling performance increased greatly with increased fan speed. Sounds normal, but this radiator shows a different performance profile than standard radiators: At 500rpm the Monsta is slightly better than its 60mm brother, but with increasing fan speed the difference increases: At 800rpm the Monsta already performs much better, and at 1200rpm a Monsta radiator is performing almost as well as a 60mm thick radiator with one fan more, at the same fan speed!
This is truly amazing, and all that at this affordable price!
Technical specifications:
Material internal: Mostly copper
Material casing: Side panels steel, threads brass, copper chambers
Colour: Black
Dimensions (LxWxH): 160 x 124 x 86mm Radiator size: 1x120mm
Connection threads: 6x1/4“
Outlet Connection threads: 1x1/4“
Mounting thread size: M3
Pressure tested: 1.5bar
Weight:
Technical Drawing
Download 3D-file (.stp)
Extent of delivery:
1x Radiator
5x screw plug
4x M3x30mm hexagon socket screw
4x M3x35mm hexagon socket screw
Similar products have been tested for you:
Hardwaremax
Review-center
hardwaremAx
Tweak (DK)
Kühlkanäle: | Kupfer |
Farbe: | schwarz |
Lüftergewinde: | M3 |
Anzahl Lüfter: | 1 |
Anschluss: | 6x G1/4" |
Lamellen: | Kupfer |
Dicke: | 69 - 100mm |
Lüftergröße: | 120mm |
Gehäuse: | Stahl |
Druckgetestet: | 2 bar |
Fins per inch: | 10 |
Abmessungen (L x B x H): | 160 x 124 x 86mm |
Liefertermin: in 8 - 9 Wochen
