Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acetal V.3
  • 13305
  • 4250197133050
  • 0,777 kg
  • 5
€83.98 *
The Alphacool VPP Apex pump including the Eisdecke D5 Acetal V.3 combines powerful... more
The Alphacool VPP Apex pump including the Eisdecke D5 Acetal V.3 combines powerful PWM-controlled pump technology with a versatile pump top. Three inlets, two outlets, and a stable mounting base allow for flexible integration into any custom loop system.
With the Eisdecke D5 Acetal V.3, the Apex VPP pump receives a housing that impresses both functionally and visually. The Eisdecke offers maximum flexibility in tube routing with a total of three inlets and two outlets. The new bracket ensures a stable stand and also allows installation in a 3.5" drive bay.
The Apex VPP is based on the well-known D5 format but has been significantly improved in key areas. Instead of a spherical bearing, it uses a ceramic shaft, which increases smooth operation and significantly reduces vibrations. Thanks to the redesigned coil layout, power consumption has been nearly halved.
Power is supplied via a modern SATA connector. The 4-pin PWM connector allows precise control and monitoring of the pump’s speed – ideal for users who demand full control over their system.
Optionally, the pump unit can be expanded into a complete pump/reservoir combo by adding a separately available reservoir top – perfect for compact and high-performance water cooling setups.
Technical data: Apex VPP Pump
Dimensions (L x W x H)65 x 65 x 41mm
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Weight276g
Technical data: Eisdecke D5 - Acetal V.3
Dimensions (L x W x H)80 x 80 x 40mm
Dimensions (L x W x H) with stand83 x 80 x 87mm
MaterialAcetal
Threads5x 1/4"
Warranty: 5 years
€11.98 *
€4.38 *
