Alphacool ES Passive Aluminium Cooler 200x120x25mm
  • 13061
  • 4250197130615
  • 0,725 kg
  • 10
€62.98*
13004 Alphacool Core 2-component heat conducting adhesive
€4.97*
13060 Alphacool ES Passive Aluminium Cooler 100x120x22mm
€25.98*
WAR Alphacool GPU RAM Aluminum Heatsinks 15x15mm - black 10 pieces.
€6.98*
Special aluminium cooler for passive air cooling of electronic components. This type of cooler... more
Special aluminium cooler for passive air cooling of electronic components. This type of cooler is often used for cooling machines, electrical as well as electronic devices and components. This method of cooling reduces the risk of hardware damage due to overheating.
The heat sink has a high number of cooling fins. This creates a large surface area that makes it possible to dissipate the generated waste heat in the best possible way. The principle is simple: the larger the surface area of the cooler, the more waste heat can be removed. This effect is further enhanced by the choice of material, as the high-quality aluminium has good thermal conductivity. The thickness of the radiator base was chosen so that the waste heat generated can be quickly transported away from the component via the cooler. The use of self-adhesive thermal pads is recommended here. These are placed between the component and the cooler and enable fast and effective heat transfer. Thermal conductive adhesive achieves the same effect here.
Since the passive cooler is made of aluminium, it is extremely light. This makes it well suited for applications where weight plays a decisive role. Important: It is necessary to note that the heat sink is made of conductive material and therefore does not come into direct contact with voltage sources.
L x W x H200 x 120 x 25mm
Materialaluminium
Number of fins27
Base thickness6,2mm
Weight700g
Colorsilver matt
Warranty: 10 years
Content 10 Stück (€0.70 * / 1 Stück)
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
Content 10 Stück (€1.40 * / 1 Stück)
63%
€1.58 * €4.28 *
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
22%
€46.98 * €59.98 *
40%
47%
€15.78 * €29.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
€1.98 * €4.47 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.01 * / 1 cm²)
€48.48 * €69.98 *
29%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.45 * / 1 cm²)
€21.38 * €29.98 *
RAD Alphacool NexXxoS Monsta 120mm Radiator
Alphacool NexXxoS Monsta 120mm radiator
€83.98 *
21%
SZ Schlauchabschneider
hose cutter
€4.97 * €6.30 *
Alphacool Silver Grease 0.5g
€1.19 *
