Alphacool Eiskoffer - measuring tool 170mm 90°
- Article no.: 90362
- EAN: 4250197136914
- Weight: 0,017 kg
- Available: Currently there are 6 available
Measuring tool 170mm 90° The flex bending attachments can only be mounted in a corner of the... more
The flex bending attachments can only be mounted in a corner of the bending plate provided for this purpose. The hole is the center of the radius measurement. You then use the radius measuring tongue to align the bending attachments. A rubber stopper that holds the measuring tongue in position ensures sufficient stability when measuring the radii.
Please note that with larger radii you also need more bending feeders.
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 für Acryl/Brass tubes - 4pcs Set Deep Black
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
Alphacool Eiszapfen 16mm HardTube compression fitting G1/4 - knurled - deep black sixpack
Content
6 Stück
(€6.00 * / 1 Stück)
€35.98
Content
240 Zentimeter
(€8.33 * / 100 Zentimeter)
€19.98
Content
240 Zentimeter
€19.98
