Alphacool Core Geforce RTX 5090 EPIC-X with backplate
- Article no.: 14739
- EAN: 4250197147392
- Weight: 1,78 kg
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Triple Fan GPU
- PNY GeForce RTX™ 5090 Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 Triple Fan GPU
Technical data cooler | |
Dimensions total (L x W x H) | 218,40 x 148,57 x 34,38mm |
Material cooler top | Acrylic |
Material terminal | Acetal |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 9 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 218,40 x 120,00 x 6,00mm |
Thick backplate without spacers | 3mm |
Material | Aluminium |
Material base plate: | Copper |
Dimensions: | 218.40 x 148.57 x 34.38mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5090; |
