Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Deep Black
- Article no.: 17196
- EAN: 4250197171960
- Weight: 0,038 kg
Get a 12% Christmas discount. The discount granted is visible in the shopping cart.
*1With the new screw-on nozzles from Alphacool for acrylic brass tubes, Alphacool takes another step towards perfection and quality.
The first two colors, Chrome and Deep Black, offer great variety. The completely coordinated product series lets each system shine in its own way and there are no limits to individuality when combined with Alphacool acrylic brass tubes!
A new chromating process firmly bonds the coloring to the brass base. This ensures the longevity of the intense color and prevents the chrome layer from chipping. Alphacool lettering on the connections further highlights the special nature of these items.
This connector is used to connect a 16mm acrylic brass tube with a 1/4 inch thread.
Technical details:
Material: brass, chromated
Colour: Deep Black
Dimension:
Width: D25.5mm
Height: 23mm
1 x Alphacool HT screw-on nozzle G1/4 for acrylic brass tubes - Deep Black
| Hersteller: | Alphacool |
| 2nd page: | 16/13mm (ID 1/2" OD 5/8") |
| Dimensions (L x W x H): | 22 x 25,5 x 17mm |
| Rotatable: | No |
| Color: | schwarz; |
| Thread length: | 5mm |
| Compatibility: | Acrylrohre;Messingrohre; |
| Material: | Messing; |
| Specification: | Shape: straight |
| 1st page: | G1/4" external thread |
