Alphacool Eiszapfen 12mm HardTube compression fitting G1/4 - knurled - deep black sixpack
  • 17375
  • 4250197173759
  • 0,128 kg
€24.98 * €29.89 * (16.43% Saved)
Content: 6 Stück (€4.16 * / 1 Stück)
Alphacool’s Eiszapfen Connector Series is the high-end execution of these tried-and-true... more
Alphacool’s Eiszapfen Connector Series is the high-end execution of these tried-and-true connectors!
Every requirement you could have of a connector is met with this series: highflow, form, processing and colour. A refusal to compromise in development and production has made the Eiszapfen series into what it is. Components are available in brilliant chrome or a deep, matte black, which will fit excellently into any system.
A special procedure binds the outer coating firmly to the surface, improving the longevity of the intense colour and preventing any chipping or peeling of the coating. Every connector now has the Alphacool logo, which along with their distinctive shape makes them unmistakable!
The slanted edges of the nut make sure the O-ring sits tight against the HardTube, so that it is even more secure than in its predecessors. This provides more security in transport.
Anyone looking for colourful options has them: the O-rings in the shipment come in three colours. With the available UV-light option, these will even light up in the corresponding colour.
Model: HardTube Compression Fitting 12mm
This connector has a 1/4" outer thread. The other side fits HardTubes with an outer diameter of 12mm.
Technical Details
  • Material: brass
  • Colour: deep black
Dimensions
  • Diameter: 20mm
  • Height: 18mm (ca. 14mm when screwed in)
Scope of Delivery
  • 1x Alphacool Eiszapfen 12mm HardTube compression fitting G1/4 for carbon tubes (rigid or hard tubes) - knurled - deep black sixpack
Drehbar: Nein
Material: Messing;
Farbe: mattschwarz;
Gewindelänge: 5mm
1. Seite: G1/4" Außengewinde
Spezifikation: Form: gerade
2. Seite: 12/10mm
Kompatibilität: Acrylrohre;harte Schläuche (PUR);Carbonrohre;
S12 Alphacool HardTube 12/10mm Acryl (PMMA) Klar 80cm - 4er Set (320cm)
Alphacool HardTube 12/10mm Acryl clear 80cm - 4pcs
Content 320 Zentimeter (€5.31 * / 100 Zentimeter)
Alphacool Core 1 Aurora Black
€119.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
€2.98 *
S13 Alphacool Eisrohr 12/9mm PETG HardTube 80cm - 4er Set (320cm)
Alphacool Eisrohr 12/9mm PETG HardTube 80cm - 4pcs
Content 320 Zentimeter (€6.87 * / 100 Zentimeter)
€21.98 *
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 200 Aurora Reservoir Acetal/Acryl with Apex Pump
€89.98 * €124.99 *
ANK Alphacool HF Schottverschraubung G1/4 - Deep Black
Alphacool HF bulkhead connector G1/4 - deep black
€5.98 *
€23.98 *
WAK Alphacool Core RX 7900XTX/XT Nitro mit Backplate
Alphacool Core RX 7900XTX/XT Nitro with Backplate
€199.98 *
Liefertermin: in 7 - 8 Wochen
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€374.90 * / 100 Zentimeter)
€74.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€7.25 * / 1 Stück)
€28.98 *
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
€44.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 ROG Strix mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 ROG Strix with Backplate
€89.99 * €159.97 *
RAD Alphacool NexXxoS HPE-30 Full Copper 280mm Radiator
€93.98 *
Leak Testing Tool incl. Pump
€34.98 *
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir Acetal/Acryl with Apex Pump
€84.98 * €118.98 *
AGB Alphacool Eisbecher Aurora D5 Acetal/Glas - 250mm
€99.98 *
RAD Alphacool NexXxoS ST25 Full Copper 360mm Radiator
Alphacool NexXxoS ST25 Full Copper 360mm radiator
€64.99 * €77.98 *
WAC Alphacool Eisblock XPX Pro Aurora Light - Acryl
€59.98 * €69.98 *
ANZ Alphacool Eiszapfen Verschlussschraube V.2 G1/4 - Deep Black
Alphacool Eiszapfen screw plug V.2 G1/4 - deep black
€3.98 *
ZSO Alphacool Eistools Montagehandschuhe Größe XL - Black
Alphacool Eistools modding gloves size XL - Black
€1.48 * €3.18 *
WAC Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€69.98 * €74.98 *
ZSO Alphacool Eistools Montagehandschuhe Größe L - Black
Alphacool Eistools modding gloves size L - Black
€1.48 * €3.18 *
WAC Alphacool Eisblock XPX Aurora - Acryl Black Digital RGB
€54.98 * €65.99 *
