Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Reference Design with Backplate
  • 14482
  • 4250197144827
  • 5,1 kg
€159.98 *
€59.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€15.39*
ROH Alphacool Eisbaer TPV Extension Set 90° (hose and connections)
€18.49*
WZS Alphacool spray bottle Core 250ml
€4.48*
13086 Alphacool Eisblock XPX Pro Aurora - Full Brass Chrome Digital RGB
€89.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Important note: The RTX 4090 Eiswolf 2 Reference AiO is not compatible with Nvidia's Geforce RTX 4090 Founders Edition.
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
Attention! For PNY GeForce RTX 4090 the rear part of the PCB is not covered. This has no negative effect on the cooling performance
Attention: Unfortunately Inno3D is using two different PCB Layouts. Please check your serial number. If it looks like following, it is not compatible with our water blocks: 32-879-xxxx8xxxx
- Inno3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X (C4090-246XX-18330005)
- Inno3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X (C4090-246XX-1833FB)
- Inno3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X (C40903-246XX-1833VA47)
- Inno3D GeForce RTX 4090 X3 OC, 24GB GDDR6X (N40903-246XX-18332989)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1-O)
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1)
Technical data radiator
Dimensions (L x W x H)395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Options for fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
Dimensions (L x W x H)198,5 x 154 x 40,5mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
Dimensions (L x D)95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions (L x W x H)120 x 120 x 25mm
Net weight187g
Max working temperature60°C
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: Nvidia GeForce
Prefilled: Yes
Content 24 Stück (€0.29 * / 1 Stück)
€6.99 *
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
€2.28 *
€2.68 *
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
€6.28 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
WAR Alphacool Eisschicht Wärmeleitpad - 17W/mK 120x20x1mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 17W/mK 120x20x1mm - 2 pieces
Content 48 cm² (€1.87 * / 1 cm²)
€89.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
