Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Gaming Trio X with Backplate
- Article no.: 14422
- EAN: 4250197144223
- Weight: 5,28 kg
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
The Eiswolf 2 cooler has a digital RGB LED lighting, also called addressable RGB LEDs. They run along the entire back of the graphics card cooler and provide complete illumination of the water cooler. The pump unit is more discreet and offers a green glowing logo for Nvidia and a red glowing logo for AMD cards. The name "Eiswolf" on the pump unit remains unlit, discreetly in the background. The fan used is the Aurora Rise with 120mm. Due to the special blade design, the fan is extremely quiet and the addressable RGB LEDs provide brilliant illumination. The Alphacool Aurora Rise fan convinces with a max. statistical pressure of 3.17mm/H2O and offers a max. air flow of 119.8m3/h. The PWM control allows the fan to be controlled over a wide speed range. In addition, it offers a zero control. It can therefore be regulated down to 0 rpm and then starts with approx. 350 rpm.
NexXxoS Radiator
Technical note!
- MSI Radeon RX 6800 Gaming X Trio 16G, 16GB GDDR6
- MSI Radeon RX 6800 XT Gaming X Trio 16G, 16GB GDDR6
Data radiator | |
L x W x H | 395 x 124 x 30mm (+/- 3%) |
Material cooling fins | Copper |
Material chambers | Copper |
Material cooling channels | Copper |
Material threads | Brass |
For fan size | 120 mm |
Possible fan assembly | 3 x one-sided / 6 x both-sided |
Data cooler and pump | |
L x W x H | 295 x 152 x 46 mm |
Material cooler bottom | Chromel plated copper |
Material cooler top | PMMA |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Data liquid | |
Color | clear |
Data quick fasteners | |
L x D | 95 x 27 mm |
Material | Nylon |
For tube size | 12,7 / 7,6 mm |
Color | Black |
Data fittings | |
L x D straight fitting | 24 x 18 mm |
L x B x H 90° fitting | 35 x 27 x 17 mm |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Data tube | |
Length | 50 cm |
Color | Matt black |
Tube size | 12,7 / 7,6 mm |
Data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Dimensions | 120 x 120 x 25 mm |
Net weight | 187 g |
Max working temperature | 60 °C |
Radiator dimensions: | 395 x 124 x 30mm |
Radiator thickness: | 29 - 39mm |
Radiator size: | 360mm |
Base: | AMD Radeon RX |
Prefilled: | Yes |
