Alphacool Eiswolf 2 AIO - 360mm RX 7900XTX Reference with Backplate
- Article no.: 13546
- EAN: 4250197135467
- Weight: 5,24 kg
- Available: Es sind weniger als 5 Artikel verfügbar
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- AMD Radeon RX 7900 XTX, 24GB GDDR6
- ASRock Radeon RX 7900 XTX, 24GB GDDR6
- Asus Radeon RX 7900 XTX, RX7900XTX-24G, 24GB GDDR6 (90YV0IT0-U0NM00)
- Biostar Radeon RX 7900 XTX, 24GB GDDR6 (VA7906AEF4)
- Gigabyte Radeon RX 7900 XTX 24G, 24GB GDDR6 (GV-R79XTX-24GC-B)
- PowerColor Radeon RX 7900 XTX, 24GB GDDR6 (RX 7900 XTX 24G)
- XFX Radeon RX 7900 XTX, 24GB GDDR6 (RX-79XMBABF9)
Technical data radiator | |
Material threads | Brass |
For fan size | 120 mm |
Dimensions (L x W x H) | 268,58 x 144,80 x 47,70 mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Net weight | 187g |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Radiatordicke: | 29 - 39mm |
Sockel: | AMD Radeon RX |
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 FTW3 mit Backplate](https://aquatuning.shop-cdn.com/media/image/54/48/ee/1020892_1sck9UZESD4Jv7_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Gaming Trio X mit Backplate](https://aquatuning.shop-cdn.com/media/image/a5/5e/9e/1020900_1mLcu2WW3SaXcK_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Strix/TUF with Backplate](https://aquatuning.shop-cdn.com/media/image/70/51/49/1021887_1FO7goJvCrT2qu_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 4080 Reference Design mit Backplate](https://aquatuning.shop-cdn.com/media/image/68/f6/48/1023273_1Hj46VqBnwiHVx_200x200..jpg)
![ROH Alphacool Eisbaer TPV Extension Set (Schlauch und Anschlüsse)](https://aquatuning.shop-cdn.com/media/image/c2/dc/f8/1019315_1k5WuKavuqDVz8_200x200..jpg)
![WÄM Alphacool Apex 17W/mK Thermal grease 4g](https://aquatuning.shop-cdn.com/media/image/2b/b5/16/1022240_1gxSgfGrdtkDJV_200x200..jpg)
![WAZ Alphacool Eiswasser Crystal Blue UV-aktiv Fertiggemisch 1000ml](https://aquatuning.shop-cdn.com/media/image/7e/67/70/1012560_1K4YIhfrcZzUvM_200x200..jpg)
![WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm](https://aquatuning.shop-cdn.com/media/image/ac/20/0e/1011296_14w5S9T4FNYWzS_200x200..jpg)
