Alphacool Eiswolf 2 AIO - 360mm RTX 4080 Strix with backplate
  • 13531
  • 4250197135313
  • 4,99 kg
€169.98 * €269.98 * (37.04% Saved)
€59.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€15.39*
WAKZ Alphacool Aurora Vertical GPU Mount with Riser Cable
€74.98*
WZS spray bottle 500ml PE-LD
€4.19*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Asus ROG Strix GeForce RTX 4080 OC, ROG-STRIX-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IC0-M0NA00)
- Asus ROG Strix GeForce RTX 4080, ROG-STRIX-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IC1-M0NA00)
- Asus TUF Gaming GeForce RTX 4080 OC, TUF-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IB0-M0NA00)
- Asus TUF Gaming GeForce RTX 4080, TUF-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IB1-M0NA00)
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X OC Edition
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X White Edition
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X White OC Edition
- Asus TUF Gaming GeForce RTX 4080 SUPER 16GB GDDR6X
- Asus TUF Gaming GeForce RTX 4080 SUPER 16GB GDDR6X OC Edition
Technical data radiator
Dimensions (L x W x H)395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Options for fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
Dimensions (L x W x H)220,90 x 166,60 x 47,60 mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
Dimensions (L x D)95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions (L x W x H)120 x 120 x 25mm
Net weight187g
Max working temperature60°C
Manufacturer: Alphacool
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: Nvidia GeForce
Prefilled: Yes
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm white
€3.18 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 15cm
€4.48 *
Content 4 Stück (€5.00 * / 1 Stück)
24%
AGB Alphacool Rise Flat Reservoir D5
€79.98 * €104.98 *
Liefertermin: in 7 - 8 Wochen
33%
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
€5.99 * €8.98 *
12%
Alphacool Ice Water Crystal Clear UV-active Ready Mix 1000ml
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pieces
€3.98 *
