CPU AIO
Close filters
from to
1 From 2
KOI Alphacool Eisbaer 240 CPU - Black Alphacool Eisbaer 240 CPU - black
With the “Eisbaer”, Alphacool is fundamentally revolutionizing the AIO cooler market. Where traditional AIO CPU-coolers are disposable products which are neither upgradeable nor refillable, the Alphacool “Eisbaer” is modularly built and...
€125.98 *
KOI Alphacool Eisbaer 360 CPU - Black Alphacool Eisbaer 360 CPU - Black
€149.98 *
KOI Alphacool Eisbaer LT240 CPU - Black PHT EOL Alphacool Eisbaer LT240 CPU - black
With the Alphacool Eisbaer LT, you get a high-performance compact water cooling system that’s barely inferior to its bigger brother, the Eisbaer AIO. Just like the Eisbaer, the Eisbaer LT distinguishes itself from the usual AIO mix in...
€119.98 *
KOI Alphacool Eisbaer LT360 CPU - Black PHT EOL Alphacool Eisbaer LT360 CPU - black
€132.98 *
KOI Alphacool Eisbaer Extreme Liquid CPU Cooler 280 - Black Edition PHT EOL Alphacool Eisbaer Extreme liquid CPU cooler 280 - black edition
Revolutionise your system with the All in One that changes everything. The Alphacool Eisbaer Extreme is stronger, more beautiful and quieter than anything you've seen before in the AiO water cooling market. Eisblock XPX- Freedom and...
€209.98 *
KOI Alphacool Eisbaer Aurora LT240 CPU AIO Digital RGB PHT EOL Alphacool Eisbaer Aurora LT240 CPU AIO Digital RGB
The Eisbaer LT Aurora CPU AIO water cooler offers extremely good cooling performance due to the high-end components, which includes a full copper radiator. The components used are all from Alphacool’s classic custom water cooling sector...
€143.98 *
KOI Alphacool Eisbaer Aurora LT360 CPU AIO Digital RGB PHT EOL Alphacool Eisbaer Aurora LT360 CPU AIO Digital RGB
€176.98 *
KOI Alphacool Eisbaer Aurora 240 CPU - Digital RGB PHT EOL Alphacool Eisbaer Aurora 240 CPU - Digital RGB
The Alphacool Eisbaer Aurora AIO CPU water cooler is a latest development of the popular and well-known Eisbaer cooler. Alphacool has improved many features but the ability to expand the cooler via the quick release fasteners and the...
€154.98 *
KOI Alphacool Eisbaer LT92 CPU - Black (without Fan) Alphacool Eisbaer LT92 CPU - black (without Fan)
The Eisbaer LT 92 has been launched especially for small form factor cases. The space SFF cases is extremely limited, therefore the Eisbaer LT 92 differs in several points from the normal Eisbaer LT. Perfect for SFF cases The cooling...
€99.98 *
KOI Alphacool Eisbaer 200 CPU - Black PHT EOL Alphacool Eisbaer 200 CPU - black
€167.98 *
KOI Alphacool Eisbaer Pro Aurora 360 CPU AIO Alphacool Eisbaer Pro Aurora 360 CPU AIO
The Alphacool Eisbaer Pro Aurora CPU AIO water cooler is a special development for processors with particularly large CPU dies. These include the AMD Threadripper and Epyc processors and the Intel CPUs for the LGA 3647 and LGA 4189...
€219.98 *
KOI Alphacool Eisbaer Pro Aurora 240 CPU AIO Alphacool Eisbaer Pro Aurora 240 CPU AIO
€198.98 *
KOI Alphacool Eisbaer Pro Aurora 280 CPU AIO Alphacool Eisbaer Pro Aurora 280 CPU AIO
€215.98 *
KOI Alphacool Eisbaer Pro Aurora 420 CPU AIO Alphacool Eisbaer Pro Aurora 420 CPU AIO
€251.98 *
11%
KOI Alphacool Eisbaer Pro ES 80mm Triple HPE + 3x ES PWM fans (AMD TR4/sTRX4/SP3/sWRX8/Intel 3647) Alphacool Eisbaer Pro ES 80mm Triple HPE + 3x ES PWM fans (AMD TR4/sTRX4/SP3/sWRX8/Intel 3647)
The Eisbaer Pro ES 2U 80mm Triple HPE AIO water cooling solution features an extremely powerful NexXxos 80mm Triple full copper radiator, equipped with high-throughput 80mm ES fans. All components used come from the Enterprise Solutions...
€176.98 * €198.98 *
KOI Alphacool Eisbaer Pro ES 80mm Quad HPE + 4x ES PWM fans (AMD TR4/sTRX4/SP3/sWRX8/Intel 3647) Alphacool Eisbaer Pro ES 80mm Quad HPE + 4x ES PWM fans (AMD TR4/sTRX4/SP3/sWRX8/Intel 3647)
The Eisbaer Pro ES 2U 80mm Quad HPE AIO water cooling solution features an extremely powerful NexXxos 80mm Quad full copper radiator, equipped with high-throughput 80mm ES fans. All components used come from the Enterprise Solutions...
€209.98 *
KOI Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO PHT EOL Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO
The Eisbaer Aurora HPE Edition 360 CPU AIO water cooling features the extremely powerful NexXxos HPE Performance all-copper radiator equipped with the high-throughput Aurora Rise 120mm fans. All of the components used come from the...
€188.98 *
38%
KOI Alphacool Core Ocean T38 AIO 280mm Alphacool Core Ocean T38 AIO 280mm
With the Core Ocean AiO, Alphacool presents an all-in-one solution that, thanks to its excellent price-performance ratio, enables entry into performance-oriented CPU water cooling. The difference to the Eisbaer CPU AiO is that the Ocean...
€47.98 * €76.98 *
1 From 2
