Temperature sensor
Close filters
SEN Alphacool Eiszapfen Temperatursensor G1/4 IG/IG & mit AG Adapter - Chrome Alphacool Eiszapfen temperature sensor G1/4 IG/IG & with AG adapter - Chrome
Alphacool icicle temperature sensor A sensor that is simply screwed into a G1/4" thread. With cable and 2-pin connection. Can be used in all exposed G1/4" threaded openings on the radiator, expansion tank, graphics card cooler...
SEN Alphacool Eiszapfen Temperatursensor G1/4 IG/IG mit AG Adapter - Deep Black Alphacool Eiszapfen temperature sensor G1/4 IG/IG mit AG Adapter - deep black
The Alphacool Eiszapfen temperature sensor flat G1/4" is a simple water temperature sensor that can be easily integrated into any water loop. Integration made easy The temperature sensor is very compact and can be integrated into any...
SEN Alphacool Eiszapfen Temperatursensor Plug G1/4 - Chrome Alphacool Eiszapfen temperature sensor plug G1/4 - Chrome
Alphacool icicle temperature sensor A sensor that is simply screwed into a G1/4" thread. With cable and 2-pin connection. Can be used in all exposed G1/4" threaded openings on the radiator, expansion tank or in a T-piece that...
SEN Alphacool Eiszapfen Temperatursensor Plug G1/4 - Deep Black Alphacool Eiszapfen temperature sensor plug G1/4 - Deep Black
Alphacool Eisfluegel temperature sensor A sensor that is simply screwed into a G1/4" thread. With cable and 2-pin connection. Can be used in all exposed G1/4" threaded openings on the radiator, expansion tank or in a T-piece...
6%
SEN Alphacool Temperatursensor Square Acetal Alphacool temperature sensor Square Acetal
The Alphacool temperature sensor Square Acetal is a simple cube-shaped water temperature sensor that can be easily integrated into any water circuit. Integration made easy The temperature sensor is very compact and can be integrated into...
€16.98 * €17.98 *
SEN Alphacool ES Durchfluss- und Temperatursensor "HighFlow" mit Tachosignal Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
The Alphacool ES "HighFlow" with tacho signal is a sensor for water temperature and water flow that can be easily integrated into any water circuit. Integration made easy The Alphacool ES "HighFlow" flow and temperature sensor is very...
€41.98 *
SEN Alphacool Core Temperatursensor mit C/F Display Alphacool Core Temperature Sensor with C/F Display
The Alphacool Core Sensor allows you to show temperature of the fluid inside your cooling loop. Thanks to the available colour display, the temperature can be read either in degrees Celsius or Fahrenheit. Integration made easy The sensor...
SEN Alphacool Core Temperatursensor G1/4 IG/IG mit C/F Display - Deep Black Alphacool Core temperature sensor G1/4 IT/IT with C/F Display - deep black
The Alphacool Core Sensor allows you to show temperature of the fluid inside your cooling loop. Thanks to the available colour display, the temperature can be read either in degrees Celsius or Fahrenheit. Integration made easy The...
€24.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz Alphacool Eiszapfen temperature sensor flat G1/4 - Black
€10.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - chrom Alphacool Eiszapfen temperature sensor flat G1/4 - chrom
€10.98 *
SEN Alphacool Thermosensor einzeln 50cm Alphacool Thermosensor single 50cm
Alphacool temperature sensor with cable and 2pin connector.
€2.68 *
