Alphacool Apex Stealth Metal Fan 2500rpm White (140x140x25mm)
  • 13773
  • 4250197137737
  • 0,564 kg
  • 5
€32.97 *
€15.98*
€37.98*
13768 Alphacool Core XT45 Full Copper 240mm Radiator
€157.98*
13873 Alphacool Core Distro Plate 240 Right D5/DDC V.2 with VPP Apex pump
€249.98*
€178.98*
13773 Alphacool Apex Stealth Metal Fan 2500rpm White (140x140x25mm) 3x
Instead of €98.91 * (10% saved) Price for all: €89.01 *
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth can be controlled between 200 to 2500 rpm via the 4-pin PWM connector. The startup speed is ~200 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Material (Frame)140 x 140 x 25mm
Material (Impeller)Die-cast zinc
Material (Impeller)Plastic
Weight400g
Speed200~2500±10% rpm
BearingHydro Dynamic Bearing
Connection4-Pin PWM
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption6.60 Watt
Rated Current0.50 A (0.55Max)
Air Flow93.9 CFM
Static Air Pressure3.45 mmH2O
Noise Level37.6 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
ColorWhite
Warranty: 5 years
