- Article no.: 17625
- EAN: 4250197176255
- Weight: 0,249 kg
*1Alphacools Eiszapfen Fitting series is the high-end version of the proven compression fitting!
All requirements that are placed on a fitting are met here: Highflow, shape, processing and color scheme. Uncompromising development and manufacturing have made the Eiszapfen what they are. In brilliant white, they blend excellently into any system.
Special processes are used to bond the coatings firmly to the substrate. The longevity of the intense colors is thus given and chipping of the coating is prevented. Each fitting has the Alphacool logo which makes it unmistakable in addition to its special shape!
The beveled edges of the compression nut press the O-ring tightly against the hose, keeping it securely in place.
Sixpack:
Since six fittings of one type are often necessary, Alphacool also offers six-packs.
| Technical data | |
| Dimensions (height x diameter) | 27 x 22mm |
| Weight | 80g |
| Material | Brass |
| Thread | 1/4" |
| Tube connection | 16/10mm |
| Color | white |
Warranty: 5 years
