Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
- Article no.: 13421
- EAN: 4250197134217
- Weight: 0,019 kg
Increased service life!
Versatile use!
| Dimensions (L x W x H) | 40 x 40 x 1mm |
| Thermal Conductivity (ASTM D5470) | 9.0 W/mK (±10%) |
| Hardness (ASTM D2240) | 50 (Shore 00) (±15) |
| Working temperature | -50 to ~180°C |
| Volume Resistance (ASTM D257) | 1×10¹² Ohm-m |
| Dielectric Breakdown Voltage (ASTM D149) | ≥8 KV/mm |
| Density (ASTM D792) | 3.2 g/cm³ (±10%) |
| Elongation (ASTM D412) | 40% |
| Color | pink |
