Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
  • 12463
  • 4250197124638
  • 0,05 kg
  • Currently there are 8 available
€48.48 * €69.98 * (30.72% Saved)
Content: 48 cm² (€1.01 * / 1 cm²)
€0.98 *
€1.19 *
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
€1.89 *
44%
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 2x 120x20x1mm
Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
Content 48 cm² (€0.53 * / 1 cm²)
€25.28 * €44.98 *
€6.49 * €8.98 *
34%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1mm - 2 pieces
Content 48 cm² (€0.69 * / 1 cm²)
€32.97 * €49.98 *
29%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.45 * / 1 cm²)
€21.38 * €29.98 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
32%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.55 * / 1 cm²)
€54.78 * €79.98 *
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x0,5mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.88 * €46.98 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
