Thermal compound
Top seller
€6.49 * €8.98 *
Alphacool Apex 2 Thermal grease 2g
Content 2 Gramm (€4,990.00 * / 1000 Gramm)
33%
€5.99 * €8.98 *
€6.99 *
€4.97 *
€1.89 *
WÄM Alphacool Apex Thermal Putty X1 30g
Content 30 Gramm (€999.33 * / 1000 Gramm)
€29.98 *
Close filters
WÄM Alphacool Silver Grease 0,5g Alphacool Silver Grease 0.5g
Alphacool's entry into the thermal paste market: Alphacool Silver Grease! Everyone needs thermal paste sooner or later when converting their system. Of course, once the system is finished, you always want the best, but of course that...
€1.19 *
WÄM Alphacool Eisfrost Xtreme Flüssigmetall Wärmeleitpaste 1g Alphacool Eisfrost Xtreme liquid metall paste 1g
Thermal compound is an issue that many users underestimate. While you usually don't want to compromise on the performance of an air or water cooler, the thermal paste often receives little attention. Yet it is the link between the heat...
€6.99 *
WÄM Alphacool Subzero Thermal grease 3,5g PHT EOL Alphacool Subzero Thermal grease 3,5g
The Alphacool Subzero Thermal Grease is intended for all users who want to achieve optimum performance with their system. This electrically non-conductive thermal paste suitable for high contact pressures is an excellent choice when...
€6.49 * €8.98 *
WÄM Alphacool Core 2-Komponenten Wärmeleitkleber 5g Alphacool Core 2-component heat conducting adhesive
Alphacool 2-part thermal adhesive is perfect for mounting coolers onto items such as motherboard VRMs. The 2-part epoxy-based adhesive is the optimal choice when coolers need to be mounted more securely onto the CPU or GPU of...
€4.97 *
20%
WÄM Alphacool Subzero Thermal grease 1g EOL Alphacool Subzero Thermal grease 1g
The Alphacool Subzero Thermal Grease is intended for all users who want to achieve optimum performance with their system. With a thermal conductivity of 16 W/mK, this electrically non-conductive thermal paste suitable for high contact...
€3.97 * €4.97 *
21%
WÄM Alphacool Subzero Thermal grease 20g EOL Alphacool Subzero Thermal grease 20g
€33.97 * €42.98 *
33%
WÄM Alphacool Rise Wärmeleitpaste 4g EOL Alphacool Rise Thermal grease 4g
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance out of their system. With moderate thermal conductivity this electrically non-conductive thermal paste is suitable for high contact pressures...
€5.99 * €8.98 *
WÄM Alphacool Apex Thermal grease 4g PHT EOL Alphacool Apex Thermal grease 4g
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum performance with their system. With a high thermal conductivity, this electrically non-conductive thermal paste suitable for high contact...
WÄM Alphacool Apex Thermal grease 1g PHT EOL Alphacool Apex Thermal grease 1g
€1.89 *
22%
WÄM Alphacool Apex Thermal grease 20g PHT EOL Alphacool Apex Thermal grease 20g
€46.98 * €59.98 *
WÄM Alphacool Apex Thermal grease 50g PHT EOL Alphacool Apex Thermal grease 50g
Content 50 Gramm (€1,399.60 * / 1000 Gramm)
€69.98 *
WÄM Alphacool Apex Thermal grease 100g PHT EOL Alphacool Apex Thermal grease 100g
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum performance with their system. With its thermal conductivity, this electrically non-conductive heat-conducting paste, which is suitable for high...
Content 100 Gramm (€1,229.70 * / 1000 Gramm)
€122.97 *
WÄM Alphacool Apex 2 Wärmeleitpaste 2g Alphacool Apex 2 Thermal grease 2g
The Alphacool Apex 2 is the next generation of the proven Apex Thermal Grease. Its new formula offers better cooling performance than its predecessor on both CPUs and GPUs, with particularly clear improvements at GPU hotspots. This makes...
WÄM Alphacool Apex Thermal Putty X1 30g Alphacool Apex Thermal Putty X1 30g
The Alphacool Apex Thermal Putty is a high-performance solution for efficiently transferring heat from heat-sensitive electronic components to a cooler. As a non-hardening silicone gel, it offers an electrically non-conductive...
€29.98 *
WÄM Alphacool Apex Thermal Putty X1 50g Alphacool Apex Thermal Putty X1 50g
Content 50 Gramm (€939.60 * / 1000 Gramm)
€46.98 *
