Alphacool Eisfach - Single/Dual DC-LT - backside modification kit
  • 15309
  • 4250197153096
  • 0,145 kg
You have the Alphacool Eisfach in the D5 or DDC version and would like to switch to the DC-LT... more
You have the Alphacool Eisfach in the D5 or DDC version and would like to switch to the DC-LT version? With this modification kit, no problem. Knowing Alphacool, any kind of modifying, expanding and upgrading is no problem, as always.
Just remove the back of the Eisfach and attach the new DC-LT back. And just like that, you have a system with the power of the DC-LT pump.
On the back:
On the right side of the back are two display spaces for 5mm LEDs, behind the window panel. This lets you create a unique look and illumination. On the left side there are two openings for filling or draining fluid. The final two 1/4” threads are meant for the inlet and outlet. Behind the inlet, a Bubble Down unit has been installed to prevent turbulence which could let air into the water circulation.
Scope of Delivery:
  • 1x Alphacool Eisfach - Single/Dual DC-LT - backside modification kit
WZS Spritzflasche 1000ml PE-LD
€6.19 *
AGB Fillport black nickel universal
€8.49 *
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
RAD Alphacool NexXxoS XT45 Full Copper 480mm Radiator
Alphacool NexXxoS XT45 Full Copper 480mm radiator
€99.98 * €126.98 *
Hint!
KAB Phobya 24Pin Netzteil Verlängerung Einzel Sleeving - Schwarz 30cm EOL
€2.58 *
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm
€5.68 *
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 30cm
€4.48 *
