Alphacool Eisbecher D5 250mm Acetal inkl. 1x Alphacool VPP655
  • PUM
  • 4250197132916
  • 1,444 kg
€129.98 * €173.72 * (25.18% Saved)
24740 Alphacool 120/140mm mounting bracket for Alphacool Eisbecher - 2 pcs
€11.98*
15277 Alphacool Aurora LED Ring 60mm - RGB
€11.98*
The Eisbecher D5 This "Eisbecher" is the big brother to the DDC version. The pump is mounted... more
The Eisbecher D5
This "Eisbecher" is the big brother to the DDC version. The pump is mounted with a mounting ring which holds the pump with eight screws. Four LEDs, which are plugged into the pump socket, illuminate this plexiglass version. The lighting module enables illumination from above. Small rising pipes and Bubble Down also do their work perfectly here. The pump can be mounted either on the bracket or the included stands. In case there is space in the 3.5" hard drive cages in the case, the pump socket also comes with the appropriate screw threads (requires pump decoupling with M4 internal and external threads - Art. 52007).
Included in Delivery:
  • 8x M4x12mm screws
  • 8x M4x8mm screws
  • 4x M4 nuts
  • 1x mounting ring
  • 1x O-ring ID ca. 54mm
  • 2x stands
  • 1x hexagonal wrench 2.5mm
Dimensions - 250mm Version:
  • Dimensions incl. bracket incl. stands (LxWxD): 324 x 136 x 80mm
  • Dimensions without bracket incl. stands (LxWxD): 324 x 87.5 x 80mm
  • Plexiglass tube diameter: 60mm
  • Capacity: 360ml
Pump: Alphacool VPP655 - Single Edition
Technical Details:
  • Dimensions (WxHxD): 65x65x57mm (without attachments)
  • Motor: electronically commutated spherical motor
  • Standard voltage: 12V DC
  • Power consumption: 23W
  • Acceptable voltage: 8-24V DC
  • Pressure at 12V: 3.7m water head
  • Maximum flow rate: 1500L/h
  • Pump fluids: water, water/glycol mixture
  • Maximum system temperature: 60°C
  • Materials used: stainless steel 1.4571, PPS-GF40, EPDM O-rings, aluminium oxide, hard carbon
  • Special features: adjustable to five levels
  • Level 1: 1800 U/min
  • Level 2: 2550 U/min
  • Level 3: 3300 U/min
  • Level 4: 4050 U/min
  • Level 5: 4800 U/min
  • Power connection: 4 pin Molex
Scope of Delivery:
  • 1x Alphacool Eisbecher D5 250mm Acetal incl. 1x Alphacool VPP655
Notice
Not intended for continuous operation with fluids containing titanium dioxide or glycerin. Many pastel colours typically use these additives.
Download 3D-file (.stp)
PUM Alphacool VPP655 - OT12 (G1/2" Außengewinde)
€99.98 *
PUM Alphacool VPP655 - T12 (1/2" Schlauchanschluss)
Alphacool VPP655 - T12 (1/2" barbed connectors)
€99.98 *
PUM Alphacool VPP655 - G1/4 IG inkl. Eisdecke D5 - Acryl V.3
Alphacool VPP655 - G1/4 inner thread including Eisdecke D5 - Acryl V.3
€99.98 * €142.78 *
PUM Alphacool VPP655 PWM - G1/4 IG inkl. Eisdecke D5 - Acetal V.3
Alphacool VPP655 PWM - G1/4 inner thread including Eisdecke D5 - Acetal V.3
€99.98 * €142.78 *
€3.98 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
€44.98 *
Content 3.5 Gramm (€3,708.57 * / 1000 Gramm)
Alphacool tube AlphaTube TPV 12,7/7,6 - black matte 3,3m (10ft) retail box
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
RAD Alphacool NexXxoS XT45 Full Copper 420mm Radiator V.2
Alphacool NexXxoS XT45 Full Copper 420mm radiator V.2
€109.98 * €124.99 *
RAD Alphacool NexXxoS XT45 Full Copper 360mm Radiator V.2
Alphacool NexXxoS XT45 Full Copper 360mm radiator V.2
€89.98 * €109.98 *
RAD Alphacool NexXxoS ST30 Full Copper 360mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
€79.98 * €92.97 *
WAK Alphacool Core RX 7900XTX Merc 310 mit Backplate
Alphacool Core RX 7900XTX Merc 310 with Backplate
€199.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
€36.99 *
€29.98 *
L12 Alphacool Core 120mm Lüfter PWM 4000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 4000rpm (120x120x25mm)
€10.98 *
Alphacool Apex Soft Thermal Pad 11W/mk 100x100x1mm
Content 100 cm² (€0.36 * / 1 cm²)
RAD Alphacool NexXxoS ST20 HPE Full Copper 120mm Radiator
Alphacool NexXxoS HPE-20 Full Copper 120mm Radiator
€55.98 *
RAD Alphacool ES Aluminium 360 mm T38  - (For Industry only)
€36.98 *
L12 Alphacool Rise Aurora 120 mm Lüfter (120x120x25mm)
€11.98 * €18.98 *
Liefertermin: in 8 - 9 Wochen
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TUF mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TUF with Backplate
€89.99 * €159.97 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X mit Backplate
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X with Backplate
€89.99 * €149.99 *
€2.98 *
Alphacool Universal feet for radiators
€24.98 *
