Alphacool Velcro mat for pump attachment
  • 13700
  • 4250197137003
  • 0,023 kg
€3.98 *
A simple but effective principle to introduce your pump into the system without transferring the... more
A simple but effective principle to introduce your pump into the system without transferring the vibrations of the rotating parts to the housing.
With scissors or a cutter, you can easily cut these pads to the desired size. Since the top and bottom of the mats are self-adhesive, any position for mounting the pump is potentially possible. Another highlight is the Velcro system. If you want to remove the pump from its original location, no problem! Simply pick it up and reattach it at a later time.
Technical data:
Color: black
Dimensions: 12cm adhesive and 12cm fleece with 10cm width
Thickness: 4mm
Fastening: self-adhesive
1x Alphacool Velcro mat for pump attachment
49%
€1.98 * €3.89 *
19%
pump shaft for Eheim 1250
€22.48 * €27.83 *
Delivery date: in 5 - 6 weeks
€3.98 *
