Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
- Article no.: RAD
- EAN: 4250197143790
- Weight: 1,239 kg
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator | |
L x W x H | 455,5 x 144 x 30mm (+/- 3%) |
Material cooling fins, pre-chambers & channels | copper |
Material threads | brass |
Threads | 4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length) |
Possible fan size | 140mm |
Possible fan assembly | 3x one-sided / 6x both-sided |
Thread size fan mounting | M3 |
Pressure tested | 0,8 Bar |
Maximum working temperature | 60°C |
Fin density | 18 FPI |
Weight | 984g |
Color | black |
Warranty: 10 years
Farbe: | schwarz |
Lamellen: | Kupfer |
Kühlkanäle: | Kupfer |
Gehäuse: | Stahl |
Lüftergewinde: | M3 |
Druckgetestet: | 0,8 bar |
Dicke: | 29 - 39mm |
Anschluss: | 5x G1/4" |
Anzahl Lüfter: | 3, 6 |
Abmessungen (L x B x H): | 455,5 x 144 x 30mm |
Fins per inch: | 18 |
Lüftergröße: | 140mm |
