O-ring 32.5x3mm NBR70
ROH O-Ring 32,5x3mm NBR70
  • 95050
  • 4049469107840
  • 0,001 kg
€0.30 *
This is a replacement seal for G1 inch thread This O-ring fits all 1 inch threads as well... more
This O-ring fits all 1 inch threads as well as the Lighttower adapter for the Phobya DC 260/400 pumps.
Technical details:
  • Dimensions: 32.5 x 3mm
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 30cm
Content 30 Zentimeter (€16.57 * / 100 Zentimeter)
€4.97 *
€1.68 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
Content 10 Stück (€0.17 * / 1 Stück)
€1.68 *
€1.48 *
62%
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 30cm
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
Content 6 Stück (€2.66 * / 1 Stück)
PUM Alphacool VPP655 PWM - G1/4 IG inkl. Eisdecke D5 - Acryl V.3
Alphacool VPP655 - PWM - G1/4 IG incl. ice cover D5 - Acrylic V.3
€99.98 * €142.78 *
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
