Alphacool Eiskamm Alu X12 - 4mm silver - 4 pieces
  • 24772
  • 4250197247726
  • 0,004 kg
€3.09 * €6.56 * (52.9% Saved)
Content: 4 Stück (€0.77 * / 1 Stück)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
The Alphacool Eiskamm Alu is the optimal solution for laying your cables neatly and maintaining the best appearance. The Eiskamm cut from aluminum tubes are much more stable than acrylic versions. To avoid damage to the sleeve, all edges are rounded. Sharp edges that could cut into the sleeve are now a thing of the past. Of course, Alphacool offers all sizes for every cable type, from SATA cables to 8-pin and 24-pin ATX cables, including different colors.
  • Material: aluminum
  • Variant: X12
  • Dimensions: 28 x 9.5 x 2.5mm
  • Color: Silver
Scope of delivery
  • Alphacool Eiskamm Alu X12 - 4mm silver - 4 pieces
Datasheet
Assembly instructions
PUZ Alphacool Klettmatte zur Pumpenbefestigung
Alphacool Velcro mat for pump attachment
€3.48 *
ZK Stromversorgungsstecker für 4Pin Molex
power connector for 4Pin Molex
€1.69 *
36%
KAB Alphacool Eiskamm Alu X4 - 4mm black - 4 Stück EOL
Content 4 Stück (€0.80 * / 1 Stück)
€3.19 * €5.02 *
36%
KAB Alphacool Eiskamm Alu X24 - 4mm silver - 2 Stück EOL
Content 2 Stück (€1.60 * / 1 Stück)
€3.19 * €5.02 *
Liefertermin: in 8 - 9 Wochen
58%
KAB Alphacool Eiskamm Alu X4 Flat - 4mm silver - 4 Stück EOL
Content 4 Stück (€0.52 * / 1 Stück)
€2.09 * €5.02 *
58%
KAB Alphacool Eiskamm Alu X4 - 4mm silver - 4 Stück EOL
€2.09 * €5.02 *
45%
KAB Alphacool Eiskamm Alu X16 - 4mm black - 4 Stück EOL
Content 4 Stück (€1.37 * / 1 Stück)
€5.49 * €9.94 *
€23.98 *
29%
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir acetal/acrylic with Apex pump
€84.98 * €118.98 *
€1.48 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Electric Blue (Paracord 550 Typ 3) 330cm
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Colonial Blue (Paracord 550 Typ 3) 330cm
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Colonial Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
61%
KAB Alphacool Eiskamm Alu X24 - 4mm red - 2 Stück EOL
Content 2 Stück (€0.95 * / 1 Stück)
€1.89 * €4.89 *
36%
KAB Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 Stück EOL
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€3.19 * €5.02 *
46%
KAB Alphacool Eiskamm Alu X16 - 4mm silver - 4 Stück EOL
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
Content 4 Stück (€1.35 * / 1 Stück)
€5.39 * €9.94 *
54%
KAB Alphacool Eiskamm Alu X8 - 4mm silver - 4 Stück EOL
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€3.19 * €6.96 *
36%
KAB Alphacool Eiskamm Alu X24 - 4mm black - 2 Stück EOL
Alphacool Eiskamm Alu X24 - 4mm black - 2 pieces
€3.19 * €5.02 *
46%
KAB Alphacool Eiskamm Alu X12 - 4mm black - 4 Stück EOL
Content 4 Stück (€1.07 * / 1 Stück)
€4.29 * €8.00 *
45%
KAB Alphacool Eiskamm X24 - 3mm black - 2 Stück EOL
Content 2 Stück (€1.10 * / 1 Stück)
€2.19 * €3.99 *
36%
KAB Alphacool Eiskamm X16 - 3mm black - 4 Stück EOL
€3.19 * €5.02 *
42%
Content 20 Zentimeter (€7.45 * / 100 Zentimeter)
€1.49 * €2.59 *
