Alphacool Aurora HardTube LED Ring 13mm Deep Black - Digital RGB
  • 15365
  • 4250197153652
  • 0,016 kg
€10.98 *
S16 Alphacool HardTube 16/11mm borosilicate glass 60cm
€25.98*
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
€24.48*
WACZ Alphacool Aurora XPX Digital RGB Frame - Chrome EOL
€6.99*
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding... more
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a pro.
Optics at its finest
The new aRGB technology gives you the option to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at any LAN party or simply at home.
Alphacool offers compatibility
With the new LED rings from Alphacool you can illuminate all hard tubes or hoses with an outer diameter of 13mm or 16mm and thus equip a variety of different systems, just as you want. The power connection is made via a 3-pin JST connector. For direct connection to a mainboard, a 3-pin JST to 3-pin aRGB adapter is required.
Technical data:
  • Inner diameter: 13 mm
  • Outer diameter: 22 mm
  • Case length: 20 mm
  • LEDs: Digital addressable RGB LEDs
  • Connector: 3-pin
  • Cable length: 75 cm
€1.48 *
€25.98 *
€6.99 *
€37.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
€5.68 *
Alphacool y-splitter aRGB 3-pin to 3x 3-pin 30cm
Content 30 Zentimeter (€16.57 * / 100 Zentimeter)
€4.97 *
€1.48 *
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
€2.48 *
