Alphacool Aurora HardTube LED Ring 13mm Deep Black - RGB
- Article no.: 15323
- EAN: 4250197153232
- Weight: 0,016 kg
The Alphacool Aurora RGB LED HardTube Ring is a perfect solution for illuminating HardTubes. The Aurora RGB LED rings are simply pushed over the HardTubes. This unique solution offers a wide range of options for customizing your own system.
Highlights
- Three RGB LEDs for optimal illumination
- Easy installation
- For HardTubes with 13mm outer diameter
- Elegant soft-touch surface
You can now customize and illuminate your system even more with the Aurora HardTube RGB LED rings. The rings are made of plastic and are equipped with three RGB LEDs inside. The soft-touch surface is identical to that of the Eisbaer. The rings can be easily pushed over the HardTubes and then provide broad and powerful illumination of the HardTubes and the liquid in the desired place. The ability to freely push the Aurora RGB LED rings over the HardTubes means you can design the structure almost freely and find the optimal look for your own taste.
Notice
The Aurora LED RGB Controller is required for the power supply and the RGB effect (Art.1013887). This is not included in the scope of delivery and must be ordered separately.
- Dimensions (DxH): 22 x 20mm
- Housing: Deep Black plastic with soft-touch surface
- LED color: RGB
- Cable: RGB male connector 15cm
Scope of delivery
- 1x Alphacool Aurora HardTube RGB LED Ring 13mm Deep Black - RGB
