Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° L-connector acrylic brass tubes - Deep Black
- Article no.: 17446
- EAN: 4250197174466
- Weight: 0,088 kg
*1With the Alphacool icicle you can connect your hard tubes at a perfect 90° angle. The hard tube is screwed tightly with the union nut, seals immediately and can be easily removed again with one hand.
Thanks to the 90° angle, the nozzle can be rotated freely (360°). The possibilities are virtually limitless.
- Width: 38mm
- Length: 38mm
- Material: Brass
- Colour: Deep Black
