Alphacool Eiszapfen 2-way ball valve G1/4 - Chrome
  • 17141
  • 4250197171410
  • 0,09 kg
Alphacool's Eiszapfen series is groundbreaking and is characterized by excellent workmanship and... more
Alphacool's Eiszapfen series is groundbreaking and is characterized by excellent workmanship and high flow.
Ball valves have always been a flow restriction and made life difficult for every pump. Alphacool has therefore developed a ball valve that does not pose an obstacle up to a diameter of 10mm.
The ball inside seals completely tightly and prevents any further liquid leaking out. All 1/4" connections with a maximum thread length of 6mm can be screwed in on both sides.
This ball valve is available in two different colours: Chrome and deep Black
Dimensions (L x W x H): 35.4 x 36 x 22.7mm
Color: Chrome
Inner diameter: 10mm !!!HIGHFLOW!!!
Scope of delivery
€37.98 *
€28.98 *
