Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Strix/TUF with backplate
- Article no.: 14479
- EAN: 4250197144797
- Weight: 5,42 kg
- Available: There are more than 5 units available
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based on the Alphacool Eisblock Aurora GPX water block, a pump unit and a 360mm NexXxoS ST30 full copper radiator. The latter is equipped with the Alphacool Aurora Rise Digital RGB fans.
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Asus ROG Strix LC GeForce RTX 3090 Ti OC, ROG-STRIX-LC-RTX3090TI-O24G-GAMING, 24GB GDDR6X (90YV0HC0-M0NA00)
- Asus ROG Strix LC GeForce RTX 3090 Ti, ROG-STRIX-LC-RTX3090TI-24G-GAMING, 24GB GDDR6X (90YV0HC2-M0NA00)
- Asus TUF Gaming GeForce RTX 3090 Ti OC, TUF-RTX3090TI-O24G-GAMING, 24GB GDDR6X (90YV0HC1-M0NA00)
- Asus TUF Gaming GeForce RTX 3090 Ti, TUF-RTX3090TI-24G-GAMING, 24GB GDDR6X (90YV0HC3-M0NA00)
| Technical data radiator | |
| L x W x H | 395 x 124 x 30mm (+/- 3%) |
| Material cooling fins, chambers & channels | Copper |
| Material threads | Brass |
| G 1/4“ threads | 2 x for tubes (+ 1x Fillport G1/4“) |
| For fan size | 120 mm |
| Possible fan assembly | 3 x one-sided / 6 x both-sided |
| Technical data cooler and pump | |
| L x W x H | 267 x 161,84 x 48,23mm |
| Material cooler bottom | Chrome plated copper |
| Threads | 2 x G1/4“ |
| Pump type | DC-LT 2 |
| Pump speed | 2600 rpm (+/- 10%) |
| Head of delivery | 1 m |
| Maximum flow rate | 72 L/h |
| Voltage | 6-13.5V DC |
| Power consumption | 3.2W |
| MTBF | 50.000 h |
| Technical data liquid | |
| Color | clear |
| Ingredient 1 | Destilled water (CAS-number 7732-18-5) |
| Ingredient 2 | Glysantin (CAS-number 1017-21-1) |
| Working temperatures | -15 C° / +90 °C |
| Technical data quick fasteners | |
| L x D | 95 x 27mm |
| Material | Nylon |
| For tube size | 12,7 / 7,6mm |
| Color | Black |
| Technical data fittings | |
| L x D straight fitting | 24 x 18mm |
| Quantity straight fittings | 2x |
| L x B x H 90° fitting | 35 x 27 x 17mm |
| Quantity 90° fittings | 2x |
| Material fittings | Brass |
| Technical data tube | |
| Length | 50cm |
| Material tube | TPV (EPDM/PP) |
| Color | Matt black |
| Tube size | 12,7 / 7,6mm |
| Hardness grade | 35 Shore-A to 50 Shore-D |
| Working temperature | -50 to +155 °C |
| Technical data fan | |
| Speed | 0 - 2500 RPM |
| Static pressure | 3,17 mm H2O |
| Air flow rate | 119,8 m³/h |
| Bearings | Sleeve bearing |
| Fan connector | 4-Pin PWM |
| Connection Digital aRGB | 3-Pin JST + 3-Pin 5V |
| Dimensions | 120 x 120 x 25mm |
| Net weight | 187g |
| Hersteller: | Alphacool |
| Radiator dimensions: | 395 x 124 x 30mm |
| Radiator thickness: | 29 - 39mm |
| Radiator size: | 360mm |
| Hose dimensions: | 12,7/7,6mm |
| Base: | Nvidia GeForce; |
| Prefilled: | Yes |
