Alphacool replacement O-rings for Eisblock GPX-N 11937
WAGZ Alphacool Ersatz O-Ringe für Eisblock GPX-N 11937
  • 13365
  • 4250197133654
  • 0,013 kg
€3.99 *
90334 Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm
€59.98*
17482 Leak Testing Tool incl. Pump
€34.98*
11937 Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Ventus with Backplate
€89.99*
14420 Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with Backplate
€269.98*
€14.98*
14465 Alphacool Filling bottle Core 250ml
€4.48*
Alphacool replacement O-rings for Eisblock GPX and Eiswolf 2. The set contains all O-rings... more
Alphacool replacement O-rings for Eisblock GPX and Eiswolf 2. The set contains all O-rings needed for complete replacement in the following cooler(s) and AIO(s)*:
- item no. 11937, Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Ventus with Backplate
- item no. 14420, Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with Backplate
(* if AIO is available)
Alphacool MCX seal plug - black 10 pcs kit
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
WAGZ Alphacool NexXxos Abstandshalter für GPX Wasserkühler
Alphacool NexXxos spacer for GPX water block
€1.98 *
WACZ Alphacool Eisberg AM3 Schaubensatz
Alphacool Eisberg AM3 screw kit
Content 4 Stück (€0.37 * / 1 Stück)
€1.48 *
