Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with Backplate
  • 14420
  • 4250197144209
  • 5,04 kg
€269.98 *
14345 Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
€79.98*
18605 Alphacool tube AlphaTube TPV 12,7/7,6 - black matte 3,3m (10ft) retail box
€18.98*
17453 Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black - 6pcs Kit
€16.98*
11772 Alphacool Eisbaer Pro Aurora 240 CPU AIO
€179.98*
24836 Alphacool Rise Aurora 120 mm fan (120x120x25mm)
€11.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 3080 Ventus 3X 10G OC, 10GB GDDR6X
- MSI GeForce RTX 3080 Ti Ventus 3X 12G OC
- MSI GeForce RTX 3090 Ventus 3X 24G OC, 24GB GDDR6X
- MSI GeForce RTX 3090 Ventus 3X 24G, 24GB GDDR6X
Technical data radiator
L x W x H395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Possible fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
L x W x H132 x 259 x 46mm
Material cooler bottomChrome plated copper
Material cooler topPMMA
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
L x D95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions120 x 120 x 25mm
Net weight187g
Max working temperature60°C
Vorbefüllt: Ja
Radiatorgröße: 360mm
Sockel: Nvidia GeForce;
KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI FTW3 mit Backplate
Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI FTW3 with Backplate
€179.98 * €269.98 *
KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Strix/TUF mit Backplate
Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Strix/TUF with Backplate
€219.98 * €269.98 *
KOI Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Founders Edition mit Backplate
Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Founders Edition with Backplate
€199.98 * €269.98 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
KOI Alphacool Eisbaer LT360 Aurora HPE CPU AIO
€179.98 *
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
Alphacool Rise Thermal grease 6W/mK 4g
€5.99 * €8.98 *
KOI Alphacool Eisbaer 360 CPU - Black
€136.98 *
