Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° L-connector acrylic brass tubes - Deep Black
- Article no.: 17444
- EAN: 4250197174442
- Weight: 0,077 kg
With the Alphacool icicle you can connect your hard tubes at a perfect 90° angle. The hard tube is screwed tightly with the union nut, seals immediately and can be easily removed again with one hand.
Thanks to the 90° angle, the nozzle can be rotated freely (360°). The possibilities are virtually limitless.
Technical details:
- Width: 34mm
- Length: 34mm
- Material: Brass
- Colour: Deep Black
