Alphacool Filling Bottle 1000ml foldable
- Article no.: 5100303
- EAN: 4070201003038
- Weight: 0,046 kg
The Alphacool filling bottle has a capacity of 1000 ml and allows for easy and precise filling... more
The Alphacool filling bottle has a capacity of 1000 ml and allows for easy and precise filling of water cooling systems.
Thanks to its thin, flexible outer material, the bottle can be folded for convenient storage. An integrated fill level scale and a transparent viewing window make it easy to check the remaining liquid at any time. The narrow, flexible filling tube allows coolant to be added directly and cleanly to the cooling system. The large filling opening with a practical screw cap also makes refilling the bottle quick and easy.
| Technical data | |
| Capacity | 1000 ml |
| Color | White |
Content
300 Zentimeter
(€4.99 * / 100 Zentimeter)
€14.98
