Alphacool Apex Glass HardTube 16/11mm 30/10cm angle
  • 5100412
  • 4070201004127
  • 0,215 kg
€24.98 *
14796 Alphacool Apex Grip HardTube fitting 16mm G1/4 black
€9.48*
14886 Alphacool Apex Grip HardTube fitting 16mm G1/4 chrome
€9.48*
14929 Alphacool Apex Grip HardTube fitting 16mm G1/4 black Set 6 pcs
€48.98*
14930 Alphacool Apex Grip HardTube fitting 16mm G1/4 chrome Set 6 pcs
€48.98*
The Alphacool Apex Glass HardTubes are made from high-quality borosilicate glass and are... more
The Alphacool Apex Glass HardTubes are made from high-quality borosilicate glass and are designed for enthusiasts and users who place particular emphasis on premium aesthetics, high material durability, and precise tube routing in their watercooling systems. The transparent glass gives any custom watercooling system a particularly high-quality appearance and showcases the cooling loop to great effect.
Borosilicate glass is characterized by its high temperature resistance, dimensional stability, and chemical resistance. Unlike many plastic hard tubes, the surface remains permanently clear and is particularly resistant to discoloration and material aging.
With an outer diameter of 16 mm and an inner diameter of 11 mm, the tubes provide a solid, premium appearance while ensuring reliable coolant flow within the cooling loop.
For easy and clean integration into a wide range of systems, Alphacool offers the Apex Glass HardTubes both as straight tubes and as precisely manufactured 90° pre-bent variants. The pre-bent tubes allow for professional tube routing without the need for complex glass bending and also reduce the number of additional angled adapters required. This makes it possible to create both straight and more complex tube runs in a clean and visually appealing way.
To cut the borosilicate glass tubes to the required length, the use of a diamond cutting disc for a Dremel® or a comparable rotary tool is recommended. Due to the specific material properties of borosilicate glass, a conventional glass cutter is not suitable for cutting these tubes.
For a clean installation, the cut edges should be carefully finished and any sharp edges removed before inserting the tube into a fitting.
The Alphacool Apex Glass HardTubes are designed for use with compatible Alphacool HardTube fittings for 16 mm tubing and are compatible with all corresponding Alphacool fittings. This ensures a secure and reliable connection within the water-cooling loop.
Due to possible design differences in fittings from other manufacturers, compatibility with third-party fittings cannot be guaranteed.
Dimensions (L1 x L2)300 x 100 mm (including the 90° bend)
Bend angle90°
MaterialBorosilicate glass
Outer diameter (mm)16 mm
Inner diameter (mm)11 mm
ColorClear transparent
S13 Alphacool HardTube 13/10mm Borosilikatglas 40cm
Alphacool HardTube 13/10mm borosilicate glass 40cm
Content 40 Zentimeter (€19.95 * / 100 Zentimeter)
S13 Alphacool HardTube 13/10mm Borosilikatglas 60cm
Alphacool HardTube 13/10mm borosilicate glass 60cm
Content 60 Zentimeter (€19.80 * / 100 Zentimeter)
€11.88 *
S16 Alphacool HardTube 16/11mm Borosilikatglas 60cm
Alphacool HardTube 16/11mm borosilicate glass 60cm
Content 60 Zentimeter (€23.30 * / 100 Zentimeter)
32%
S16 Alphacool HardTube 16/11mm 90° Borosilikatglas 10/30cm
Alphacool HardTube 16/11mm 90° borosilicate glass 10/30cm
€16.98 * €24.98 *
