Alphacool HF Compression Fitting 11/8mm G1/4 Black
  • 5100337
  • 4070201003373
  • 0,028 kg
€4.47 *
Terms and Conditions Alphacool Eisstation 40 DC-LT - Container
€37.98*
S11 Alphacool hose AlphaTube HF 11/8 (5/16"ID) - Ultra Clear 3m (9.8ft) "Retail Package" 300cm
€9.98*
S11 Alphacool Hose AlphaTube HF 11/8 (5/16"ID) - UV-active Black 3m (9.8ft) "Retail Package" 300c
€11.98*
S11 Alphacool EPDM Tube 11/8 - Black 3m (9.84ft) retail box
€15.98*
14571 Alphacool ES Reservoir DDCzero 1U with Pump
€159.98*
The Alphacool HF 11/8mm hose fitting for tubing with an 11/8mm diameter is part of Alphacool’s... more
The Alphacool HF 11/8mm hose fitting for tubing with an 11/8mm diameter is part of Alphacool’s HF series and sets new standards in functionality and flow performance for watercooling systems.
Made from robust brass, the high-flow fitting features an optimized internal diameter that reduces flow resistance and enables a high coolant flow rate. This makes the fitting particularly suitable for performance-oriented custom watercooling systems where unrestricted flow within the loop is a key priority.
Thanks to the standardized G1/4" thread, the hose fitting can be combined with a wide range of components. The design is specifically tailored to tubing with an outer diameter of 11 mm and an inner diameter of 8 mm, ensuring a secure fit and reliable sealing.
In addition to its functionality, the HF hose fitting blends discreetly into a wide variety of water cooling setups thanks to its black finish. The compact design enables clean and unobtrusive tube routing and complements both minimalist and more elaborate systems.
Height23.92 mm
Diameter17.03 mm
Material FittingBrass (CuZn39Pb3)
Connection typeTube connection 11/8 mm
Thread connectionG 1/4
Thread length5 mm
Seal materialEPDM Shore A 70
ColorBlack
