Alphacool Apex Manifold 360mm
  • 14678
  • 4250197146784
  • 1,016 kg
€189.98 *
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - Chrome
€6.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Chrome
€8.98*
ANS Alphacool Eiszapfen 16/10mm screw-on nozzle G1/4 - Chrome
€6.98*
ANS Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - Chrome
€8.98*
14795 Alphacool Apex Grip HardTube fitting 13mm G1/4 black
€8.98*
14796 Alphacool Apex Grip HardTube fitting 16mm G1/4 black
€9.48*
14797 Alphacool Apex Grip SoftTube fitting 13/10mm G1/4 black
€7.98*
14807 Alphacool Apex Grip adapter 90° OT/IT G1/4 rotatable black
€12.98*
14808 Alphacool Apex Grip adapter 45° OT/IT G1/4 rotatable black
€9.98*
The Apex Manifold 360mm is the ideal solution for a visually unique custom water-cooling build.... more
The Apex Manifold 360mm is the ideal solution for a visually unique custom water-cooling build. Thanks to its numerous connection options, it enables especially clean tubing runs and creates a neat, organized appearance inside the system.
Four chambers and eight G1/4" inlet and outlet ports offer versatile options for integrating various components into the water-cooling loop. This allows hard tubes or soft tubes to be routed particularly straight and easily, giving the entire custom loop an exceptional look. The Apex Manifold 360mm supports the connection of at least three components and stands out with high-quality brass threads, which effectively help prevent the risk of leaks caused by cracking, integrated aRGB lighting that can be controlled via a digital aRGB header on the motherboard or optionally via the Alphacool Aurora Eiscontrol aRGB Controller (item no. 15360), and the distinctive Apex design featuring chrome-plated brass elements and clear acrylic.
Thanks to its various mounting options, the Apex Manifold 360mm can be installed flexibly in a wide range of positions inside the case. It can be mounted directly to a radiator, both with and without fans. In addition, the Apex Manifold 360mm can be mounted next to water-cooling components such as tube reservoirs. This is made possible by an extensive mounting kit. Mounting to the PCIe bracket can also be achieved using the included kit.
The Apex Manifold 360mm can be mounted either front-facing or rotated by 90° on the bracket. This allows it to be optimally adapted to the system layout and integrated even more effectively into the water-cooling loop.
With its transparent acrylic body in the Apex design, the manifold not only improves the structure of the loop, but also elevates the overall aesthetics of the water-cooling system to a new level.
Dimensions (L x W x H)360,00 x 36,00 x 24,00 mm
MaterialAcrylic
Threads8x G1/4“ brass thread
Working pressure0.0 - 1.0 Bar
Pressure tested0.8 Bar
Maximum pressure2.0 Bar
Quantity digital aRGB LEDs18
Power digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Weight764g
ColorChrome | Transparent
