Alphacool Apex AM5 Contact Frame
- Article no.: 5100065
- EAN: 4070201000655
- Weight: 0,05 kg
*1The Alphacool Apex Contact Frame AM5 was specifically developed for AMD processors using the AM5 socket. It provides reliable sealing of the exposed capacitors around the processor while also helping to distribute the mounting pressure evenly.
The even mounting pressure ensures optimal contact between the CPU cooler and the processor. This creates the ideal foundation for reliable heat transfer between the CPU and the cooler, supporting efficient system cooling.
The Contact Frame can be easily integrated into existing AM5 systems and is compatible with all Alphacool CPU coolers that support the AM5 socket. This makes it an ideal functional addition for high-performance gaming PCs, workstations, and custom-built water-cooling systems.
AMD AM5 Sockets
| Technical data | |
| Material | Aluminum alloy (AlMg1SiCu) |
| Material Screw | Stainless steel (X10CrNi18-8) |
This item is available exclusively outside Germany and cannot be purchased within Germany.
