Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
- Article no.: 13493
- EAN: 4250197134934
- Weight: 0,068 kg
Powerful!
Increased lifespan!
Versatile!
| Dimensions (L x W x H) | 100 x 100 x 1,5mm |
| Thermal Conductivity (ASTM D5470) | 16.6 W/mK (±10%) |
| Hardness (ASTM D2240) | 65 (Shore 00) (±5) |
| Working temperature | -50 to ~150°C |
| Volume Resistance (ASTM D257) | 5×10¹² Ohm-m |
| Dielectric Breakdown Voltage (ASTM D149) | 5 KV/mm (±10%) |
| Density (ASTM D792) | 3.6 g/cm³ (±10%) |
| Elongation (ASTM D412) | 20% |
| Color | dark grey |
